[GRASS-user] Region definition in Grass 6.1 (and 6.1 cvs)
Mon Aug 21 04:12:34 EDT 2006
Michael Barton wrote:
> > - region matches display (cut region at nearest cell boundary)
> Region for non-display modules matches the region set for rendering a map to
> the current display. This is pretty much how things work in normal mode if
> run from the GIS Manager menus.
The problem is that, when you have multiple displays, it's likely to
be unclear as to which one determines the region used by non-display
commands.
Also, requiring the region to match one of the displays is problematic
if you are working at a relatively high resolution. You don't want to
have to force the displays to operate at that resolution simply
because you cannot make a command use a resolution which doesn't match
a display.
