[GRASS-user] nviz max resolution ppm image dump
William Hargrove hnw at fire.esd.ornl.gov
Mon Aug 28 22:51:12 EDT 2006
This is 6.1.0 built from source, running under 64-bit FC 5.
Here is what happens when I try to dump a max-res ppm:
recalculating normals...
Diagnostic: invalid command name "Nviz_animation_save" --  Save
procedure for panel animation may not be defined
Diagnostic: invalid command name "Nviz_kanimator_save" --  Save
procedure for panel kanimator may not be defined
Diagnostic: invalid command name "Nviz_query_save" --  Save procedure
for panel query may not be defined
Diagnostic: invalid command name "Nviz_sdiff_save" --  Save procedure
for panel sdiff may not be defined
Diagnostic: invalid command name "Nviz_label_save" --  Save procedure
for panel label may not be defined
Diagnostic: invalid command name "Nviz_scale_save" --  Save procedure
for panel scale may not be defined
Diagnostic: invalid command name "Nviz_pos_save" --  Save procedure for
panel pos may not be defined
Diagnostic: invalid command name "Nviz_resize_save" --  Save procedure
for panel resize may not be defined
Diagnostic: invalid command name "Nviz_pick_save" --  Save procedure for
panel pick may not be defined
Diagnostic: invalid command name "Nviz_highlight_save" --  Save
procedure for panel highlight may not be defined
Creating PBuffer Using GLX 1.3
Final Assembled Image will be 1 x 1
Writing Tile 1 of 1
Assembling Tiles
GLX -- destroy pbuffer
./donviz: line 2: 10088 Segmentation fault      nviz
elevation=elev48.new color=neon2.25 vector=states100,neondomains_states
Any ideas?
Thanks,
Bill H.
Hamish wrote:
>William Hargrove wrote:
>>My nviz dies with a segfault when I try to dump an image as maximum
>>resolution ppm.
>>I have this same problem with grass 6.1 under FC 5, and under grass
>>5.4 under FC 4.
>what's the date on the 6.1? 6.1.0 or 6.1-cvs? This was an old known
>problem on 64bit &/or big endian (Mac G5), I had thought that it was
>fixed by Glynn & crew some months ago.
>>I can dump the other formats just fine.
>>The map products look great on the screen, but aren't much use if I
>>can't get them into a high-res image file.
>>Does anyone have any advice on this problem?
>http://intevation.de/rt/webrt?serial_num=3041
>perhaps that bug referes to a slightly different problem?
>Hamish
William W. Hargrove                     hnw at fire.esd.ornl.gov
Environmental Sciences Division         (865) 241-2748
Oak Ridge National Laboratory           (865) 574-4665 (fax)
P.O. Box 2008, M.S. 6407                http://research.esd.ornl.gov/~hnw
Oak Ridge, TN  37830-6407               FedEx/UPS, use "Bethel Valley Rd."
