[GRASS-user] [bug #3041] nviz max resolution ppm image dump
William Hargrove hnw at fire.esd.ornl.gov
Wed Aug 30 08:41:05 EDT 2006
Hamish, Glynn:
The 6.1.0 version of nviz dumps high res ppms perfectly after I comment
out the off-screen section.
So the bug that remains in the subsequent versions must come from code
changes introduced since then.
Bill H.
Glynn Clements wrote:
>Hamish wrote:
>>>Note that setting the environment variables:
>>>	GRASS_NO_GLX_PBUFFERS
>>>	GRASS_NO_GLX_PIXMAPS
>>>will disable use of these features, in case of problems with your
>>>OpenGL setup (libraries or X server). Their values don't matter, only
>>>whether or not they are set.
>>These should be added to lib/init/variables.html
>I'll do that.
>>Setting those make no difference to this bug however:
>>#with GLX
>>G63 > nviz elevation.10m
>>% Creating PBuffer Using GLX 1.3
>>Create PixMap Using GLX 1.1
>>Final Assembled Image will be 1929 x 2048
>>Assembling Tiles
>>pnmcat: EOF / read error reading a row of pixels
>>#without GLX
>>G63> export GRASS_NO_GLX_PBUFFERS=TRUE
>>G63> export GRASS_NO_GLX_PIXMAPS=TRUE
>>G63> nviz elevation.10m
>>% Final Assembled Image will be 1904 x 2048
>>Assembling Tiles
>>pnmcat: Zero byte allocation
>Well, it appears to make *some* difference, i.e. you're getting a
>different error message.
>Does removing the following from nviz2.2_script help?
>	# Set the cancel function for drawing
>	Nset_cancel_func update
William W. Hargrove                     hnw at fire.esd.ornl.gov
Environmental Sciences Division         (865) 241-2748
Oak Ridge National Laboratory           (865) 574-4665 (fax)
P.O. Box 2008, M.S. 6407                http://research.esd.ornl.gov/~hnw
Oak Ridge, TN  37830-6407               FedEx/UPS, use "Bethel Valley Rd."
