[GRASS-user] r.in.onearth
    lanczos at t-zones.sk
    Wed Aug 30 18:46:47 EDT 2006
Trying to use the r.in.onearth on the way like below:
r.in.onearth -l output=landsat_tm_7 file=/tmp/test tmband=visual 'wgetopt=-t 0'
I got the error message like below (see the output in the P.S.) The Grass is 6.3.CVS from 20.8.2006, compiled on Ubuntu 6.06.
What's wrong - something with Gdal, the wget or is it a bug of the r.in.onearth?
Thanks
Tomas
p.s. the output:
Will download and import LandsatTM Data with band visual
************** DOWNLOAD DATA ****************
Requesting Data from http://wms.jpl.nasa.gov/wms.cgi
--00:41:52--  http://wms.jpl.nasa.gov/wms.cgi
           => `/home/tomas/grassdata/srtm40_03/tomas/.tmp/tomas/10568.0/Image_global_mosaic_base_visual_6019_12020'
Resolving wms.jpl.nasa.gov... 137.78.11.25
Connecting to wms.jpl.nasa.gov|137.78.11.25|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/vnd.ogc.se_xml]
    0K                                                           7.21 MB/s
00:41:54 (7.21 MB/s) - `/home/tomas/grassdata/srtm40_03/tomas/.tmp/tomas/10568.0/Image_global_mosaic_base_visual_6019_12020' saved [325]
Downloaded file is not a GeoTiff file, but will try to import
************** CHECK DATA *****************
ERROR 4: `/home/tomas/grassdata/srtm40_03/tomas/.tmp/tomas/10568.0/Image_global_mosaic_base_visual_6019_12020' not recognised as a supported file format.
GDALOpen failed - 4
GDALOpen failed - 4
!-------------------BREAK---------------------!
Downloaded file is not supported by gdal, or cannot be imported
File of Type:  XML document text
Message from Server http://wms.jpl.nasa.gov/wms.cgi
!------------BEGIN-ERROR-MESSGAE--------------!
<?xml version='1.0' encoding="UTF-8" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd ">
<ServiceExceptionReport version="1.1.0">
  <ServiceException>
    Requested image is too wide, max allowed width is 4096
  </ServiceException>
</ServiceExceptionReport>
!-------------END-ERROR-MESSGAE---------------!
Finished
