[GRASS-user] AAIGrid import-export problem
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Fri Dec 1 11:34:54 EST 2006
I tested various r.out.gdal settings (-r is a very handy function! - thanks
Hamish) and found no errors using various files.
Finally I ended up doing further test with r.resamp.stats where I found the
problem.
Hence r.out.gdal shows no inconsistency but r.resamp.stats - I'll post another
message concerning this behaviour in a few minutes.
Martin
On Friday 01 December 2006 01:51, Hamish wrote:
> Martin Wegmann wrote:
> > On Thursday 30 November 2006 13:43, Wolfgang wrote:
> > > have you changed g.region to your new settings before export?
> > I changed g.region res. during the r.resamp.stats but for export of
> > the two raster g.region wasn't changed
> > BTW r.info of the two raster gives same res/coord. for both.
> what about with using the new region sensitive GDAL output? (resamples)
> "r.out.gdal -r"
> r.in.gdal out=NAME
> g.region rast=NAME
> r.out.gdal -r in=NAME
> Hamish
