[GRASS-user] AAIGrid import-export problem
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Fri Dec 1 13:31:33 EST 2006
Hello Dylan,
On Friday 01 December 2006 19:23, Dylan Beaudette wrote:
> I am interested in hearing about the issues you have observed with
> r.resamp.stats.
> I too have noticed some odd behaviour when the input/output resolution is
> the same : a systematic shift occurs.
> an example with spearfish60:
> g.region rast=elevation.dem
> r.resamp.stats in=elevation.dem out=r method=average
> d.rast elevation.dem
> r.mapcalc "rd = float(elevation.dem - r)"
> d.rast rd
> r.info rd
hmm, interesting - I assume it is the same behaviour and due to the larger
area I am working on, my shift is more pronounced.
Attached a jpg of r and elevation.dem correlation (Moving Window size 3x3
multiplied with 1000) - the deviation from 1000 (or corr. val 1) is just
present in parts of the image - I would have assumed that the whole image has
a constant deviation from 1000, hence there might be another error.
Martin
> Cheers,
> Dylan
> On Friday 01 December 2006 08:34, Martin Wegmann wrote:
> > I tested various r.out.gdal settings (-r is a very handy function! -
> > thanks Hamish) and found no errors using various files.
> > Finally I ended up doing further test with r.resamp.stats where I found
> > the problem.
> > Hence r.out.gdal shows no inconsistency but r.resamp.stats - I'll post
> > another message concerning this behaviour in a few minutes.
> > Martin
> > > > On Thursday 30 November 2006 13:43, Wolfgang wrote:
> > > > > have you changed g.region to your new settings before export?
> > > > I changed g.region res. during the r.resamp.stats but for export of
> > > > the two raster g.region wasn't changed
> > > > BTW r.info of the two raster gives same res/coord. for both.
> > > what about with using the new region sensitive GDAL output? (resamples)
> > > "r.out.gdal -r"
> > > r.in.gdal out=NAME
> > > g.region rast=NAME
> > > r.out.gdal -r in=NAME
> > > Hamish
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20061201/35bfaa5d/correlatio_r_elevDEM.jpg.jpg
