[GRASS-user] 'ARNing: Cannot open driver 'dbf"
Mon Dec 4 19:30:40 EST 2006
Raymond Fu wrote:
>   GRASS 6.1.cvs (spearfish60):~>v.db.connect -p map=roads driver=dbf
>   Vector map <roads> is connected by:
>   layer <1> table <roads> in database <home/xxx/spearfish60/PERMENANT/dbf/>
>   hoguh driver <dbf> with key <cat>
>   GRASS 6.1.cvs (spearfish60):~>g.copy vect=roads,roads_local
>   COPY [roads at PERMANENT] to current mapset as [roads_local]
>   DBMI-DBF driver error:
>   Cannot open dbf database: roads
>   WARNING: Cannot open database 'roads'
>   no database is open
>   WARNING: Cannot copy table
>   WARNING: Cannot copy roads at PERMANENT to current mapset as roads_local
Does the database exist on the disk?
g.gisenv
cd $MAPSET
ls dbf/
Hamish
