[GRASS-user] v.surf.rst limitations?
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Tue Dec 5 13:10:10 EST 2006
Roberto, can v.surf.bspline work with opint data imported as
v.in.ascii -vbt? I mean, without topolopgy nor table? Or I do need a
table?
thanks
Carlos
On 12/4/06, roberto.antolin at polimi.it <roberto.antolin at polimi.it> wrote:
> Hi Michael and all
> Michael Perdue <michael_perdue at yahoo.ca> ha escrito:
> > Hey Roberto,
> > Can you tell me more about this bug? I ran a tile through
> > v.surf.bspline that was significantly larger than this and I never
> > ran into any problems. Nor can I find any defects in the output.
> > This grid was 33mil cells with ~30mil input data points.
> Good to know! :)  I had some problems with memory allocation weeks ago
> and I was probably wrong about the number of cell v.surf.bspline can
> manage. I'll check again. Thank you for the information.
> > However, I do receive a seg fault when I try to define a set of
> > sparce data nodes to be interolated (input_ext=).
> Yes, this is one of the "many" bugs. But, at least, this is also
> fixed. A new patch will be available tomorrow (I think).  This new
> patch will also include a best stdout info. Well, it will actually
> include stdout info :-P
> Just a curiosity, how much time did it take to run? Maybe the new
> version makes it to run faster ;-) Let me know, please.
> > Cheers,
> > Mike
> > PS Yes, v.surf.bspline is much faster than v.surf.rst. But more
> > importantly, it seems to step through the data to prevent memory
> > allocation errors. Is this true? Nice!!! :-)
> Yes, that's totally true. If the current region is too large, it
> divides the whole region into smaller regions and it works with them
> one at a time. The module also considered overlapped zones between
> sub-regions to avoid discontinuities in the dtm heights.
> Regards,
> Roberto.
> PS: I think the mailing list didn't receive my last mail, did it?. If
> that's right, I'm sorry. I have tons of problems with my mail server.
> However, you can find it below.
> > At this moment, there is actually a limitation with v.surf.bspline.
> > There is a bug and I think it is no possible working with 13.5 mill
> > cells. I'm working on it, but by the moment It will reach only 4mill
> > cells. Yes, I know it is no enough, sorry. I hope that in a near future
> > this will be also fixed. Maybe, if you try with a lower resolution
> > (about 20m) v.surf.bspline should work.
> > However, I think v.surf.bspline will be faster than v.surf.rst. ;-)
> > Regards,
> > Roberto.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
