[GRASS-user] grass 6.3cvs stability
Precila Salcedo precy11 at yahoo.com
Wed Dec 6 19:10:48 EST 2006
Hi Malte,
thanks a lot, i tried doing several things but failed
to get result.. these the things i did that got not
result.. what seems to be the problem with these? i
need to import shapefiles and work with my files
ASAP..Thanks...
i was importing vector files by:
file/import/vector map/various formats using OGR...
(other choices were ASCII points file or GRASS ASCII
vector file, Input old GRASS vector format, dxf file,
ESERI e00 format, Garmin GPS Waypoints/Routes/Tracks,
GEO net Name server country files (US-NGA GNS), Matlab
& MapGen files)
here's what i did:
v.in.ogr -l dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP
output=cities.grc min_area=0.0001 snap=-1
Data source contains 1 layers:
CITIES
v.in.ogr -l -f -c -z -t -o -e
dsn=E:/paj/flora_diversity.shp
output=c:/GIS/PGS/DATABASE/Flora_tst.shp
Available OGR Drivers:
  ESRI Shapefile
  MapInfo File
  UK .NTF
  SDTS
  TIGER
  S57
  DGN
  VRT
  AVCBin
  REC
  Memory
  CSV
  GML
  SQLite
  PostgreSQL
  ESRI Shapefile
  MapInfo File
  UK .NTF
  SDTS
  TIGER
  S57
  DGN
  VRT
  AVCBin
  REC
  Memory
  CSV
  GML
  SQLite
  PostgreSQL
v.in.ogr -l -f -z -e
dsn=C:/ESRI/ESRIDATA/EUROPE/country.shp
output=cntrygraz.ogr {layer=ESRI
Shapefile:country.shp} type=boundary snap=-1
location=C:/GIS/PGS
  ESRI Shapefile
  MapInfo File
  UK .NTF
  SDTS
  TIGER
  S57
  DGN
  VRT
  AVCBin
  REC
  Memory
  CSV
  GML
  SQLite
  PostgreSQL
v.in.ogr -l dsn=C:/ESRI/ESRIDATA/europe.apr
output=citiesgraz {layer=ESRI Shapefile:cities.shp}
snap=-1
--- Malte Halbey-Martin <malte at perlomat.de> wrote:
> Hi Precila,
> GRASS can import shape files or open it.
> just use the gis manager or the command line option
> v.in.ogr dsn=yourshapefile.shp output=yourvectorfile
> or take a closer look at
http://grass.itc.it/grass63/manuals/html63_user/v.in.ogr.html
> Malte
> Precila Salcedo schrieb:
> > hello there,
> > i just installed Grass 6.3CVS..this is my first
> time
> > to use it after several attempts of installing
> it..my
> > promotor would like us to use this software here
> in
> > europe rather than using the expensive commercial
> > software..since it is under development, may i
> know if
> > its possible to import/open ESRI shapefiles? I
> DONT
> > KNOW HOW TO DO IT, i dont have any knowledge in
> > language programming or any other computer courses
> as
> > well, im just a student with other technical field
> of
> > specialization..Any help would be greatly
> appreciated.
> > Thanks a lot.
> > Precila
____________________________________________________________________________________
> > Do you Yahoo!?
> > Everyone is raving about the all-new Yahoo! Mail
> beta.
> > http://new.mail.yahoo.com
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
Want to start your own business?
Learn how on Yahoo! Small Business.
http://smallbusiness.yahoo.com/r-index
