[GRASS-user] 'ARNing: Cannot open driver 'dbf"
Raymond Fu raymond_fu at yahoo.com
Wed Dec 6 21:57:53 EST 2006
hi,
  Today I try again.
  GRASS 6.1.cvs(spearfish60):~> eval `g.gisenv`
  GRASS 6.1.cvs(spearfish60):~> echo $MAPSET
  user1
  GRASS 6.1.cvs(spearfish60):~>cd "$GISBASE/$LOCATION_NAME/$MAPSET"
  bash: cd: /usr/local/grass6.1.cvs/spearfish60/user1: No such file or directory.
  I try to exame the location from window explorer, and I can found the road.dbf in c:\cwgin\home\xxx\spearfish60\PERMANENT\dbf\
  Both command d.rast roads, d.what.vect works fine.   The road can be displayed and I can use mouse to read the features attributes from a prompt window.
  Thanks.
  Raymond
Hamish <hamish_nospam at yahoo.com> wrote:
  Raymond Fu wrote:
> The result is as follows:
> GRASS 6.1.cvs(spearfish60):~>eval `g.gisenv`
> GRASS 6.1.cvs(spearfish60):~>echo $MAPSET
> user1
> GRASS 6.1.cvs(spearfish60):~/spearfish60/user1> ls dbf
> ls: cannot access dbf: No such file or directory.
> I guess the reason is because the road is orginally in PERMENANT
> Mapset. What I am trying to do to copy the road from PERMENANT to
> user1 Mapset using g.copy command.
sorry,
eval `g.gisenv`
cd "$GISBASE/$LOCATION_NAME/PERMANENT"
ls dbf/
I am interested to know if the DBF file works.
d.rast roads
d.what.vect
Hamish
 Send instant messages to your online friends http://uk.messenger.yahoo.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061207/a9f4046e/attachment.html
