[GRASS-user] [newbie] How to split an area with v.digit?
Robert Pollak robert.pollak at scietec.at
Thu Dec 7 04:23:03 EST 2006
Tom Russo schrieb:
>> I have used v.digit to define a closed area with several border vertices
>> and a centroid.
>> Now I want to subdivide the area into two parts. How can I do this?
> Near as I can tell, one can get close to this by digitizing the first areas,
> then digitizing the splitting lines so that they intersect the exisitng
> boundaries, then using v.clean to break lines at intersections and remove
> dangles.
Thank you - this is cubersome, but working.
I am defining an intersecting border line, then I use
GRASS 6.0.1 (spearfish60):~ > v.clean input=map1 output=map2
tool=break,rmdangle thresh=0,30
-- Robert
