[GRASS-user] grass 6.3cvs stability
Malte Halbey-Martin malte at perlomat.de
Thu Dec 7 06:18:40 EST 2006
Hi
as far  as I see, you used the -l switch which causes v.in.ogr to list
all available layer and exit without importing the shape file. Just turn
out that switch
(on the command line:
v.in.ogr dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP output=cities.grc min_area=0.0001 snap=-1
or disable the button in the gis manager)
and than it must work. normally a status of the import is displayed. You
can check if the import worked on the command line with:
g.list vect
Precila Salcedo schrieb:
> Hi Malte,
> thanks a lot, i tried doing several things but failed
> to get result.. these the things i did that got not
> result.. what seems to be the problem with these? i
> need to import shapefiles and work with my files
> ASAP..Thanks...
> i was importing vector files by:
> file/import/vector map/various formats using OGR...
> (other choices were ASCII points file or GRASS ASCII
> vector file, Input old GRASS vector format, dxf file,
> ESERI e00 format, Garmin GPS Waypoints/Routes/Tracks,
> GEO net Name server country files (US-NGA GNS), Matlab
> & MapGen files)
> here's what i did:
> v.in.ogr -l dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP
> Data source contains 1 layers:
> CITIES
> v.in.ogr -l -f -c -z -t -o -e
> dsn=E:/paj/flora_diversity.shp
> output=c:/GIS/PGS/DATABASE/Flora_tst.shp
> Available OGR Drivers:
>   ESRI Shapefile
>   MapInfo File
>   UK .NTF
>   SDTS
>   TIGER
>   S57
>   DGN
>   VRT
>   AVCBin
>   REC
>   Memory
>   CSV
>   GML
>   SQLite
>   PostgreSQL
>   GRASS
>   ESRI Shapefile
>   MapInfo File
>   UK .NTF
>   SDTS
>   TIGER
>   S57
>   DGN
>   VRT
>   AVCBin
>   REC
>   Memory
>   CSV
>   GML
>   SQLite
>   PostgreSQL
>   GRASS
> v.in.ogr -l -f -z -e
> dsn=C:/ESRI/ESRIDATA/EUROPE/country.shp
> output=cntrygraz.ogr {layer=ESRI
> Shapefile:country.shp} type=boundary snap=-1
> location=C:/GIS/PGS
>   ESRI Shapefile
>   MapInfo File
>   UK .NTF
>   SDTS
>   TIGER
>   S57
>   DGN
>   VRT
>   AVCBin
>   REC
>   Memory
>   CSV
>   GML
>   SQLite
>   PostgreSQL
>   GRASS
> v.in.ogr -l dsn=C:/ESRI/ESRIDATA/europe.apr
> output=citiesgraz {layer=ESRI Shapefile:cities.shp}
> snap=-1
> --- Malte Halbey-Martin <malte at perlomat.de> wrote:
>> Hi Precila,
>> GRASS can import shape files or open it.
>> just use the gis manager or the command line option
>> v.in.ogr dsn=yourshapefile.shp output=yourvectorfile
>> or take a closer look at
> http://grass.itc.it/grass63/manuals/html63_user/v.in.ogr.html
>> Malte
>>> hello there,
>>> i just installed Grass 6.3CVS..this is my first
>> time
>>> to use it after several attempts of installing
>> it..my
>>> promotor would like us to use this software here
>> in
>>> europe rather than using the expensive commercial
>>> software..since it is under development, may i
>> know if
>>> its possible to import/open ESRI shapefiles? I
>> DONT
>>> KNOW HOW TO DO IT, i dont have any knowledge in
>>> language programming or any other computer courses
>> as
>>> well, im just a student with other technical field
>> of
>>> specialization..Any help would be greatly
>> appreciated.
>>> Thanks a lot.
>>> Precila
> ____________________________________________________________________________________
>>> Do you Yahoo!?
>>> Everyone is raving about the all-new Yahoo! Mail
>> beta.
>>> http://new.mail.yahoo.com
>>> grassuser mailing list
>>> grassuser at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grassuser
> Want to start your own business?
> Learn how on Yahoo! Small Business.
> http://smallbusiness.yahoo.com/r-index
