[GRASS-user] grass 6.3cvs stability
Precila Salcedo precy11 at yahoo.com
Thu Dec 7 06:42:10 EST 2006
--- Hamish <hamish_nospam at yahoo.com> wrote:
> Precila Salcedo wrote:
> > thanks a lot, i tried doing several things but
> failed
> > here's what i did:
> > v.in.ogr -l dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP
> output=cities.grc min_area=0.0001 snap=-1
> > Data source contains 1 layers:
> > CITIES
> Hi Precila,
> from the help page:
> Flags:
>   -l   List available layers in data source and exit
> so when you used the list flag it exited before
> importing anything.
> try this:
> v.in.ogr dsn=C:/ESRI/ESRIDATA/WORLD/CITIES.SHP
> output=cities.grc
>    which is the same as this:
> v.in.ogr dsn=C:/ESRI/ESRIDATA/WORLD/ layer=CITIES
> output=cities.grc
> Hamish
Hi Hamish,
i tried your suggestion by opening grass and typing
the command straight on the Output GIS.m panel (lower
half of the panel) then RUN it;
output=cities.grc
how will i open it now?..i was looking for the file
cities.grc but cant find it, was it automatically
saved on my default location or somewhere else? my
default dataset is Spearfish60 PERMANENT. wil i open
it using file/workspace/open or using
file/import/vector map???? ..im having difficulty with
this.  thanks a lot.
Precy
____________________________________________________________________________________
Any questions? Get answers on any topic at www.Answers.yahoo.com.  Try it now.
