[GRASS-user] Failed to process SRS definition when TIGER2000 is being imported.
Raymond Fu raymond_fu at yahoo.com
Sun Dec 10 21:57:40 EST 2006
hi,
  I have try your suggestion, but it return the following erors:
  GRASS 6.1.cvs(spearfish60):~>ogr2ogr -srs EPSG:4269 -t_srs EPSG:26713 tgr46081lkA_UTM13_nad27.shp tgr46081lkA.shp
  ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of OGRCoordinateTransfromation failed.
  Failed to create coordinate transformation between the following coordinate systems.  This may be because they are not transformable, or because projection services (PROJ.4 DLL/.so) could not be loaded.
  Segmentation fault (core dumped)
  I am using GRASS 6.1cvs version.  Any ideas?
  Thanks in advance,
  Raymond.
Tom Russo <russo at bogodyn.org> wrote:
  On Fri, Dec 08, 2006 at 05:07:49PM +0800, we recorded a bogon-computron collision of the flavor, containing:
> By the way when I try to import ESRI Shape files(TIGER2000) by the fellowing command ogr2ogr -s_srs "+init=epsg:4269" -t_srs "+init=epsg:26713" tgr46081lKA_UTM13_nad27.shp tgr46081lkA.shp, it returns "Failed to process SRS definition: +init=epsg:4269. Do I need install anything additional plugin to make it work?
Try instead:
ogr2ogr -s_srs EPSG:4269 -t_srs EPSG:26713
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
 Send instant messages to your online friends http://uk.messenger.yahoo.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061211/a81242b8/attachment.html
