[GRASS-user] r.le.setup trouble
Koen Hufkens koen.hufkens at ua.ac.be
Tue Dec 12 04:16:35 EST 2006
I installed the debian packages and everything runs fine but my problem
isn't resolved with the upgrade.
I'll try to read in my input data again, maybe this will help.
Koen
On Tue, 2006-12-12 at 01:12 +0100, Hamish wrote:
> Hamish wrote:
> > > What version of GRASS? There were substantial fixes for r.le.setup
> > > right before GRASS 6.2.0 was released. If 6.3-cvs, check out r.li
> > > too.
> Koen Hufkens wrote:
> > I'm using 6.0.2 from the ubuntu repositories.
> Ok, you will need to use GRASS 6.2.x. if you want to use r.le.* as it
> is
> somewhat broken in 6.0.2.
> > I'm currently looking for a repository offering a more recent
> release
> > but I don't seem to find one.
> Jachym's; also you might try the DebianGIS experimental amd64 version:
>   http://packages.debian.org/grass
> or compile it yourself. my instructions are for Debian, but Ubuntu
> should be near identical:
> http://grass.gdf-hannover.de/wiki/Compile_and_Install#Platform_Specific_Notes
>   http://hamish.bowman.googlepages.com/debiangisfiles#compile
> > generic binary packages
> These are not for a debian based distro, so I worry that these could
> be
> more problematic in the long-run due to different library naming, etc.
> versus compiling it yourself.
> Hamish
