[GRASS-user] Grass installation problem on Solaris 9
Harri Kiiskinen harkiisk at utu.fi
Thu Dec 14 05:45:27 EST 2006
Hello,
I see you have selected to compile GRASS with 64bit support enabled, and
that you are using gcc as a compiler, and ld is used as the linker. Two
comments:
>From the Solaris CC manual can be found the information, that ld should
not be used to link 64bit binaries; CC should be used for that purpose
('CC -G' or 'CC -g', 'man CC' will give the necessary info). You could
try changing the relevant part in include/Make/Platform.make . I have
tried to report this as a bug a couple of times, but to no avail...
Alternatively you might try to specify the path to the GNU ld, as the
generic name ld probably indicates Solaris ld, for which the
above-mentioned restriction applies.
The above-mentioned trick might require the compilation with the Solaris
cc, which in my case always worked nicely.
Greetings,
Harri K.
to, 2006-12-14 kello 00:15 -0800, Brad Douglas kirjoitti:
> On Thu, 2006-12-14 at 10:57 +0500, capricorn 80 wrote:
> > Hi ! I have to past full messages so that u people can figure out whats the
> > main problem in it So that i can install grass on solaris.
> > Following are my messages when i compile grass-6.2.1RC1 on solaris 9.
> > GRASS is now configured for:  sparc-sun-solaris2.9
> > Source directory:            /opt/grass/grass-6.2.1RC1
> > Build directory:             /opt/grass/grass-6.2.1RC1
> > Installation directory:      /usr/local/grass-6.2.1RC1
> > Startup script in directory: ${exec_prefix}/bin
> > C compiler:                  gcc -g -O2
> > C++ compiler:
> > FORTRAN compiler:
> > Building shared libraries:   yes
> > 64bit support:               yes
> > OpenGL platform:             X11
> >   NVIZ:                       yes
> >   BLAS support:               no
> >   C++ support:                no
> >   DWG support:                no
> >   FFMPEG support:             no
> >   FFTW support:               yes
> >   FreeType support:           no
> >   GDAL support:               yes
> >   GLw support:                no
> >   JPEG support:               yes
> >   LAPACK support:             no
> >   Large File Support (LFS):   yes
> >   Motif support:              no
> >   MySQL support:              no
> >   NLS support:                no
> >   ODBC support:               no
> >   OGR support:                yes
> >   OpenGL support:             yes
> >   PNG support:                yes
> >   PostgreSQL support:         yes
> >   Python support:             yes
> >   Readline support:           no
> >   SQLite support:             no
> >   Tcl/Tk support:             yes
> >   TIFF support:               yes
> >   X11 support:                yes
> > bash-2.05# make
> > Then i execute command Following modules are missing the 'description.html'
> > file in src code:
> > i.find
> > GRASS GIS compilation log
> > Started compilation: Thu Dec 14 09:29:03 PKT 2006
> > Errors in:
> > /opt/grass/grass-6.2.1RC1/lib/gmath
> > /opt/grass/grass-6.2.1RC1/lib/db/sqlp
> > /opt/grass/grass-6.2.1RC1/lib/imagery
> > /opt/grass/grass-6.2.1RC1/lib/rst/interp_float
> > /opt/grass/grass-6.2.1RC1/lib/init
> > /opt/grass/grass-6.2.1RC1/db/drivers/dbf
> > /opt/grass/grass-6.2.1RC1/db/drivers/postgres
> > /opt/grass/grass-6.2.1RC1/db/drivers/ogr
> > /opt/grass/grass-6.2.1RC1/display/d.colors
> > /opt/grass/grass-6.2.1RC1/general/g.access
> > /opt/grass/grass-6.2.1RC1/general/g.mapsets
> > /opt/grass/grass-6.2.1RC1/general/g.transform
> > /opt/grass/grass-6.2.1RC1/imagery/i.class
> > and few more messages like this.
> > Then i change the directory and try to make i.e
> > bash-2.05# cd /opt/grass/grass-6.2.1RC1/lib/gmath
> > bash-2.05# make
> > <unknown>                           0x18
> > /usr/local/lib/libfftw3.a(t1_4.o)
> > <unknown>                           0x14
> > /usr/local/lib/libfftw3.a(t1_5.o)
> > <unknown>                           0x18
> > <unknown>                           0x14
> > /usr/local/lib/libfftw3.a(t1_6.o)
> > <unknown>                           0x18
> > <unknown>                           0x14
> > /usr/local/lib/libfftw3.a(t1_7.o)
> > <unknown>                           0x18
> > <unknown>                           0x14
> > /usr/local/lib/libfftw3.a(t1_8.o)
> > <unknown>                           0x18
> > <unknown>                           0x14
> > /usr/local/lib/libfftw3.a(t1_9.o)
> > <unknown>                           0x18
> > <unknown>                           0x14
> > /usr/local/lib/libfftw3.a(t1_10.o)
> > <unknown>                           0x18
> > <unknown>                           0x14
> > /usr/local/lib/libfftw3.a(t1_12.o)
> > <unknown>                           0x18
> > ld: fatal: relocations remain against allocatable but non-writable sections
> > collect2: ld returned 1 exit status
> > make: ***
> > [/opt/grass/grass-6.2.1RC1/dist.sparc-sun-solaris2.9/lib/libgrass_gmath.6.2.1RC1.so]
> > Error 1
> This thread may be related:
> http://www.filibeto.org/pipermail/solaris-users/2004-March/000660.html
