[GRASS-user] Re: r.in.xyz memory error
Ken grass at kwasnicki.com
Thu Dec 14 18:49:34 EST 2006
ooops... should read the man pages more carefully.  "percent="
Ken wrote:
> I'm using r.in.xyz to import an ascii x/y/z file with about 2 million
> points.   While r.in.xyz is scanning data  I monitor it using "top"
> and I can see a VIRT memory size of 863m and the RES memory climbs
> fairly quickly up to that amount and then I get the following error:
> ERROR: G_calloc: out of memory
> I have 1GB physical ram on my system + 1GB swap space.   Is this
> expected behaviour for r.in.xyz? Any suggestions for getting it to run
> successfully within the ram constraints of my system?
> Or, perhaps there's a better way to do what I'm trying to do?  I have
> a postgres table with 10 million x,y,z points (which will grow to
> about 100m).  I want to perform queries to extract various regions of
> points and create raster layers in grass from those points.
> Currently I'm writing my query results to an output file and then
> importing with r.in.xyz.   Is there a better way to do this which
> might solve my memory issue above?
> Thanks!
> Ken
