[GRASS-user] Add a module to already installed Grass 6.2.1
Dylan Beaudette dylan.beaudette at gmail.com
Tue Dec 19 14:25:54 EST 2006
On Tuesday 19 December 2006 06:10, Patrick Meyfroidt wrote:
> Hello,
> I very recently installed Grass 6.2.1 on my Ubuntu Dapper machine.
> I would like to use the module r.resamp.stats which is not available
> in this version of Grass.
> Is it possible to add this (or another) module after installation?
> How is it possible to do that?
> Thank you very much,
> Patrick Meyfroidt
Hi Patrick,
Did you install via source or binary? If you installed via binary, then you
will need to get a more current binary distribution of GRASS.
If you compiled from source, you can always get the lates CVS copy and
re-compile. as for inserting newer code into an exisiting source branch...
not sure if this will work- the other devs might have a better solution. In
general i have found that using the CVS branch is the best way to stay up to
date.
Cheers,
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
