[GRASS-user] Profile from a random path
Dylan Beaudette dylan.beaudette at gmail.com
Wed Dec 20 18:14:33 EST 2006
On Wednesday 20 December 2006 05:55, Hamish wrote:
> Luca Casagrande wrote:
> > I have got a path described by a vector line; i'd like to create the
> > elevation profile for that line without using GUI.
> maybe something with v.drape?
> > 3) Use r.profile as described in the example 3 to create the profile
> > for the ascii file.
> > I focused on the 3rd problem:
> > In the r.profile man page, in the example 3 section, it says this:
> > Example 3
> > Extract a profile with coordinates provided from standard input or an
> > external file: First create a points file with d.where
> > d.where > saved.points
> > Then pipe the points file into r.profile
> > cat saved.points | r.profile input=elev.rast output=profile.pts
> > The matter is that if i run the command line shown in the example, it
> > doesn't work, cause it need -i flag or to set the profile= one with
> > the coordinates of points.
> > Any idea?
> The error message is wrong. That's been broken for ~6 years..
> thanks for pointing it out. fixed in CVS + 6.2 branch.
> Added this example to the help page:
> #spearfish
> r.profile elevation.dem res=1000 << EOF
>   591243,4926344
>   592509,4922156
>   594100,4920793
>   599910,4919365
>   602929,4919235
>   604844,4918391
>   606468,4917190
>   607766,4915664
> EOF
> this now works too:
>  d.where | r.profile elevation.dem
> Hamish
Luca:
did this solve your problem? I recall doing something like this a while back
using v.drape.
If you like R here is the code I usually use for plotting distance along line
(3d) vs elevation: (grass and R code):
# make new line
v.digit -n map=t bgcmd="d.rast elev_meters"
# convert to points
v.to.points in=t out=tp type=line dmax=50 -i -v -t
# set resolution
g.region -pa res=4
# make 3d
v.drape in=tp out=tpz type=point rast=elev_4m method=cubic
# export
v.out.ascii tpz > tpz.txt
# start R
R
# read in the data, note that there is no header, and the columns are pipe
delimited
x <- read.table('tpz.txt', header=F, sep="|",
col.names=c('easting','northing','elev','f'))
# use attach for simple access to columns
attach(x)
# compute the length minus 1 ; i.e. the number of points - 1
# use for the lagged distance calculation
s <- length(easting) - 1
# calculate the lagged distance along each component of the 3D vector
dx <- easting[2:(s+1)] - easting[1:s]
dy <- northing[2:(s+1)] - northing[1:s]
dz <- elev[2:(s+1)] - elev[1:s]
# combine the vector components
# 3D distance formula
c <- sqrt( dx^2 + dy^2 + dz^2)
# create the cumulative distance along line:
dist <- cumsum(c[1:s])
# plot the results
plot(dist, elev[1:s], type='l', xlab='Distance from start (m)',
ylab='Elevation (m)', main='Profile')
# cleanup
detach(x)
see attached figure for output
I can put this up on the R-wiki for later use. it might be fun to code this
into something, so that there are fewer steps involved...
Cheers,
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20061220/bb3bb7e2/profile.png
