[GRASS-user] FW: Holiday GUI updates to GRASS
Michael Barton michael.barton at asu.edu
Wed Dec 20 17:51:44 EST 2006
I meant to post this to both the developer and user list.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
------ Forwarded Message
> From: Michael Barton <michael.barton at asu.edu>
> Date: Wed, 20 Dec 2006 10:55:10 -0700
> To: Grass Developers List <grass-dev at grass.itc.it>
> Conversation: Holiday GUI updates to GRASS
> Subject: Holiday GUI updates to GRASS
> I just committed a number of GUI updates to GRASS which will hopefully make
> some people happy for the holidays.
> 1. The title bar on the map layer window looks a bit nicer
> 2. You can now select panel options by clicking the icon/button in the map
> layer window. Previously, you had to click the text.
> 3. I did a complete makeover to the EPSG projection setting GUI. There is now
> a search engine that allows you to search for any text string, will
> automatically grab the associated EPSG code, and put it into the EPSG code
> entry window.
> 4. I put all the define new region code into the tcltk script (it was in a
> separate bash script) so that it is now Windows-compatible (I hope). Some of
> this code will go away with planned improvements to g.proj.
> 5. When you define a location using the EPSG module, it automatically updates
> the locations list so that you don't have to restart GRASS to see the new
> location.
> 6. I did a few cosmetic improvements to the main startup window (button
> placement and consistent relief height).
> Cheers
> Michael
> phone: 480-965-6213
> fax: 480-965-7671
------ End of Forwarded Message
