[GRASS-user] shaded relief of srtm tiles
thorsten
thorsten at robotronic.info
Thu Dec 21 16:28:55 EST 2006
thank you Hamish,
patching works fine ( http://www.flickr.com/photos/h2guide/329431459 ),
but i try to create a shaded relief of a hughe area,
so i will have to process it tile by tile.
what i am actually doing is:
r.in.srtm input=N42W005 output=tile #r.in.srtm input=N42W004 output=tile
g.region rast=tile
r.colors map=tile rules=srtm
r.shaded.relief map=tile shadedmap=relief altitude=44 azimuth=270
units=meters
r.his h_map=tile i_map=relief r_map=final.red g_map=final.green
b_map=final.blue
r.composite red=final.red green=final.green blue=final.blue levels=32
output=final;
"final" is the shaded and colored relief.
what do you mean by "absolute" color table?
i am using the predefined color table "srtm"
and the result is still different for the adjacent tiles:
http://www.flickr.com/photos/h2guide/329431463
pasting the colored maps (called "tile") together looks ok:
http://www.flickr.com/photos/h2guide/329472914
so the problem is the greyscale component (called "relief") produced by
r.shaded.relief:
http://www.flickr.com/photos/h2guide/328146671
What should I do to get seamless tiles?
Thorsten
Hamish wrote:
>thorsten wrote:
>>hello list,
>>i try to use r.shaded.relief on srtm tiles imported with r.in.srtm.
>>the results look nice, but adjacent tiles have a different average
>>brightness.
>>I used the same parameters (altitude=44 azimuth=270 units=meters) for
>>both maps and tried with grass versions 6.02 and 6.20
>>That's how it looks like for the original srtm tiles N42W005.hgt.zip
>>and N42W004.hgt.zip:
>>http://www.flickr.com/photos/h2guide/328146671/
>>What am i doing wrong? (Or what am i supposed to do in order to produce
>>seamless shaded reliefs?)
>try setting an absolute color table with r.colors,
>or merge the two tiles first:
>g.region rast=tile1,tile2
>r.patch in=tile1,tile2 out=tile_merge
>Hamish
