[GRASS-user] create a point map
Moritz Lennert mlennert at club.worldonline.be
Fri Dec 22 10:50:23 EST 2006
On Thu, December 21, 2006 20:59, Abbott, Dawn wrote:
> You may also want to try r.in.ascii.  I found that in GRASS 6.1 r.in.xyz
> does not exist.
Unless you are sure you want a raster map, I would actually recommend
v.in.ascii.
Moritz
> -----Original Message-----
> From: grassuser-bounces at grass.itc.it on behalf of Patton, Eric
> Sent: Thu 12/21/2006 10:00 AM
> To: Janet Choate
> Cc: grassuser at grass.itc.it
> Subject: RE: [GRASS-user] create a point map
> Janet,
> Have a look at r.in.xyz:
> http://grass.itc.it/grass63/manuals/html63_user/r.in.xyz.html
> Eric Patton
> email: epatton at nrcan.gc.ca
> ________________________________
> [mailto:grassuser-bounces at grass.itc.it] On Behalf Of Janet Choate
> 	Sent: Thursday, December 21, 2006 12:18 PM
> 	To: grassuser at grass.itc.it
> 	Subject: [GRASS-user] create a point map
> 	Hello,
> 	I'd appreciate any help with this.  I have a list of Easting and
> Northing coords, along with a value for each point.  I'd like to turn
> this into a map that I can then display and use for analysis.  Or at the
> very least, is there a command that will allow me to identify where a
> given easting/northing is located in the display?
> 	Thank You
> 	Janet
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
