[GRASSLIST:10124] RE: updates to gism2 - Feb2, 2006
Patton, Eric epatton at nrcan.gc.ca
Thu Feb 2 09:29:50 EST 2006
Hi Michael,
I downloaded gism_rc1_20060201 this morning and gave it a try; thanks for
the updates! We're definitely getting closer here.
Some observations:
1) Clicking the 'Open existing workspace file' button opens a 'Save File'
dialog box. Shouldn't this be an Open File box?
2) Trying to open a Workspace file through File/Groups/Open menu gives an
error. I've attached it as 'Open Workspace Error.log'.
3) I created a workspace file from scratch. I added 2 rasters to the gis
manager, then clicked File/Groups/Save as which gave the error message
attached in 'Save_Workspace_Error.log'. I am able to save the workspace
using the GUI button on the display manager, however. The saved workspace
file re-opens normally.
4) Most Grass commands typed into the run dialog don't seem to do anything.
I only tried a few commands, i.e. g.region -p, d.rast map=rastername don't
run, but r.composite does. Do only a subset of Grass programs run in this
dialog?
5) Once a code block is pasted into the 'run' dialog, clicking the 'save'
button produces an error message, which is attached as
Command_Save_Error.log.
HTH,
~ Eric.
-----Original Message-----
To: grass developers list; Multiple recipients of list
Sent: 2/1/2006 7:55 PM
Subject: [GRASSLIST:10120] updates to gism2
I posted to my web site and Markus helped me commit to the cvs a set of
updates to the GIS Manager 2 GUI that addresses some of the issues that
popped up over the last couple days.
I noticed that I cannot produce text overlays on my Mac using d.text or
d.text.freetype. I'd like to know if this is the same under other OS's
also. d.label does work, however.
d.text.freetype has not worked on the Mac since the upgrade to OSX10.4,
but d.text did work. So I need to know if this is a Mac issue or
everyone has the same lack of text under the new TclTk canvas displays.
If the latter, I can add a TclTk text module that will do essentially
the same thing as d.text.freetype and should work on all systems.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
<http://www.public.asu.edu/~cmbarton>
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060202/16dc6c01/Open_Workspace_Error.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060202/16dc6c01/Save_Workspace_Error.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060202/16dc6c01/Command_Save_Error.obj
