[GRASSLIST:10125] Polylining line segments
Steven Gordon sg at cartagram.com
Thu Feb 2 09:35:04 EST 2006
Thanks for the help on the v.patch command. That quickly merged all
of the layers together that I needed combined.
About the v.build.polyline command...Does this command join line
segments that share all share-able attributes?
For example, the U.S. Census Tiger road line data has attributes for
length, node ID, street name, street type, and so forth. Because the
attribute values are different, the v.build.polyline command must
join segments whose attribute values can be shared (like street name)
while ignoring attribute values that have to be unique for each line
segment (length, ID). Is that correct?
   Steven Gordon
