[GRASSLIST:10219] Re: Labels and ps.map
Thu Feb 9 05:48:22 EST 2006
Nick Cahill wrote:
> Ps.map works fine for me until I add a label to the map; then
> although the file is written OK, it cannot be opened - it gives a
> parsing error in Adobe Illustrator or any other program I use to open
> it. If I leave the label command out of the ps.map command file, it
> works fine, so the problem is there. I vaguely recall a thread about
> this but can't track it down. I've tried 6.0 and last  cvs on Mac OSX
> 10.4.3. Any thoughts?
1. What error message are you getting?
2. Can you provide a small PostScript file which demonstrates the
problem? Or, alternatively, a ps.map script which works in one of the
sample locations (e.g. Spearfish)?
