[GRASSLIST:10223] Re: Problems with r.proj - grass 6.01
Morten Hulden morten at untamo.net
Thu Feb 9 08:48:12 EST 2006
Hi Helmut,
I suspect your input map and output region are only overlapping by a few
cells (2 colums with 4 rows each). Therefore your map appears empty, but
I think you should see something in 8 cells in one corner.
Both the imput map and output location are in tmerc projection with
lat_0=0. But:
Input North: 5321295.600000
Output South: 5353002.550472
shows that the northmost latitude of the input map does not reach the
southmost latitude of the output region.
You could try to extend your output region, at least soutward, and try
again.
rgds
Morten
Helmut Kudrnovsky wrote:
> there is no difference between the options "with region cropping" (look at 1) and "without region cropping" (look at 2)
> i tried this procedure with different output-projections which are matching for germany/austria and different region-settings and different interpolation methods (cubic, bilinear).
> Input Projection Parameters: +proj=tmerc +lat_0=0 +lon_0=13.33333333333333 +k=1.000000 +x_0=450000 +y_0=0 +no_defs +a=6377397.155 +rf=299.1528128 +towgs84=577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
> Input Unit Factor: 1
> Output Projection Parameters: +proj=tmerc +lat_0=0 +lon_0=12 +k=1.000000 +x_0=4500000 +y_0=0 +no_defs +a=6377397.155 +rf=299.1528128 +towgs84=597.1,71.4,412.1,0.894,0.068,-1.563,7.58
> Output Unit Factor: 1
> Input:
> Cols:	2349 (2349)
> Rows:	2347 (2347)
> North: 5321295.600000 (5321295.600000)
> South: 5318948.400000 (5318948.400000)
> West:  4561644.000000 (4561644.000000)
> East:  4563992.800000 (4563992.800000)
> ew-res:	0.999915
> ns-res:	1.000085
> Output:
> Cols:	4373 (2)
> Rows:	3210 (4)
> North: 5356212.272416 (5356212.272416)
> South: 5353002.550472 (5353002.550472)
> West:  8604787.256327 (8604787.256327)
> East:  8609160.077374 (8609160.077374)
> ew-res:	0.999959
> ns-res:	0.999913
