[GRASSLIST:10225] RE: Three questions on ps.map
Morten Sickel Morten.Sickel at nrpa.no
Thu Feb 9 09:27:31 EST 2006
Sorry for 'bumping' my post, but these problems are important to me. Any
body having an Idea? 8The first one, I can fix with some manual editing
of the ps file, the others are worse..
Morten
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Morten Sickel
Sent: Tuesday, February 07, 2006 9:01 PM
To: grasslist at baylor.edu
Subject: [GRASSLIST:10194] Three questions on ps.map
Hi
I am using ps.map and I have a few questions regarding it. My map is
build up with a number of vector layers
1) I am getting a frame around the map. Is that possible to avoid?
2) Is it possible to put the unit on the scale bar?
3) I have a vector layer with a closed polygon where I just want to draw
the outline. I tried using vlines, but then nothing showed up. This may
also be some problem with how the layer is defined.
Morten
