[GRASSLIST:10251] Re: gismlegend.txt problem
Ing.Peter Misovic peter.misovic at gmail.com
Fri Feb 10 17:18:39 EST 2006
Hi Michael again,
the problem is that d.vect.thematic is not creating this file anymore.
If I create this file by my own (in my default directory)
d.vect.thematic is not terminated abnormally. Even though that fact,
the file has Ob size and GIS Monitor displays nothing at all.
Thank you for you help,
Peter
On 2/10/06, Michael Barton <michael.barton at asu.edu> wrote:
> This problem may happen to other people.
> In order to make a legend in the new GIS Manager,  must
> create a text file containing legend parameters and give it a name that gism
> can recognize. So, I've had d.vect.thematic write these out to a file named
> gismlegend.txt in the user's default directory (usually the home directory).
> If you cannot write to your default directory--whatever it
> is--gismlegend.txt won't get written and the GIS Manager won't find it.
> See if you are getting this file written into your default directory. If
> not, try making sure the permissions are set to let you write in the
> directory.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: "Ing.Peter Misovic" <peter.misovic at gmail.com>
> > Date: Thu, 9 Feb 2006 23:35:42 +0100
> > To: grass list <GRASSLIST at baylor.edu>
> > Subject: [GRASSLIST:10232] gismlegend.txt problem
> > Dear all,
> > I have problem in GM2 during following process:
> > a.) open d.vect.thematic
> > b.) setting of all related parameters
> > c.) switch to grass monitor
> > d.) click on redraw icon (top-left)
> > d.) error occuring : couldn't open "gismlegend.txt": no such file or directory
> > Thank you,
> > Peter
