[GRASSLIST:10255] Re: gismlegend.txt problem
Michael Barton michael.barton at asu.edu
Fri Feb 10 18:23:00 EST 2006
You should already have v.univar.sh in a normal GRASS distribution. However,
it looks like you needed the new d.vect.thematic.
You are also correct that you need to install v.what if you want to do
vector querying.
These steps are listed in the README file that accompanies the version of
the GIS Manager that comes from my web site. All the appropriate files
should also be in the cvs.
Let me know if they are not.
Glad it is working.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: "Ing.Peter Misovic" <peter.misovic at gmail.com>
> Date: Sat, 11 Feb 2006 00:11:32 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Multiple recipients of list <GRASSLIST at baylor.edu>
> Subject: Re: [GRASSLIST:10232] gismlegend.txt problem
> Hi again ;)
> the problem was soleved by following way (maybe it can help somebody):
> a.) Download thematic.tgz from
> http://www.public.asu.edu/~cmbarton/files/grass_scripts/
> b.) copy d.vect.thematic and v.univar.sh into (grass dir/scripts)
> c.) manually create gismlegend.txt in you default directory
> My fault was that I did not copy v.univar.sh into scripts folder.
> This is how I installed v.what. Maybe, it could help somebody.
> a.) download gism_rc2_20060206.tgz from
> http://www.public.asu.edu/%7Ecmbarton/files/grass_gismgr/ - package
> contains new Gis Manager and new v.what script. First of all, create
> folder v.what in (unTARed folder with grass sources)/vector/ and copy
> all files from v.what/source/v.what.tar.gz into this new folder.
> b.) run ./configure as you need, then make (as normal user)
> c.) go into vector/v.what folder and run make
> d.) do #make install (as root)
> Peter
> On 2/10/06, Ing.Peter Misovic <peter.misovic at gmail.com> wrote:
>> Hi Michael again,
>> the problem is that d.vect.thematic is not creating this file anymore.
>> If I create this file by my own (in my default directory)
>> d.vect.thematic is not terminated abnormally. Even though that fact,
>> the file has Ob size and GIS Monitor displays nothing at all.
>> Thank you for you help,
>> Peter
>> On 2/10/06, Michael Barton <michael.barton at asu.edu> wrote:
>>> This problem may happen to other people.
>>> In order to make a legend in the new GIS Manager,  must
>>> create a text file containing legend parameters and give it a name that gism
>>> can recognize. So, I've had d.vect.thematic write these out to a file named
>>> gismlegend.txt in the user's default directory (usually the home directory).
>>> If you cannot write to your default directory--whatever it
>>> is--gismlegend.txt won't get written and the GIS Manager won't find it.
>>> See if you are getting this file written into your default directory. If
>>> not, try making sure the permissions are set to let you write in the
>>> directory.
>>> Michael
>>> __________________________________________
>>> phone: 480-965-6213
>>> fax: 480-965-7671
>>>> Date: Thu, 9 Feb 2006 23:35:42 +0100
>>>> To: grass list <GRASSLIST at baylor.edu>
>>>> Subject: [GRASSLIST:10232] gismlegend.txt problem
>>>> Dear all,
>>>> I have problem in GM2 during following process:
>>>> a.) open d.vect.thematic
>>>> b.) setting of all related parameters
>>>> c.) switch to grass monitor
>>>> d.) click on redraw icon (top-left)
>>>> d.) error occuring : couldn't open "gismlegend.txt": no such file or
>>>> directory
>>>> Thank you,
>>>> Peter
