[GRASSLIST:10319] Re: importing big ECW file with r.in.gdal
Martin Landa landa.martin at gmail.com
Wed Feb 15 12:25:27 EST 2006
Hi Markus,
do you mean --enable-largefile?, it is enabled...
Martin
2006/2/15, Markus Neteler <neteler at itc.it>:
> Martin,
> do you have LFS enabled everywhere?
> Markus
> Martin Landa wrote:
> >Hi *,
> >I am trying to import a big (~1.7GB) ECW file downloaded from
> > http://www.geotorrent.org/details.php?id=30
> >I can visualize this raster map in QGIS without any problems. I would
> >like to import it into a GRASS location. I have used r.in.gdal module,
> >but the import was not successful. The RGB channels were generated,
> >for example the green one:
> >  | Layer:    eu.blue                        Date: Mon Feb 13 01:31:46 2006    |
> >  | Mapset:   PERMANENT                      Login of Creator: martin          |
> > | Location: eu_mozaika                                                       |
> >  | DataBase: /mnt/hdb1/grassdata                                              |
> >  | Title:     ( eu.blue )                                                     |
> > |   Type of Map:  raster               Number of Categories: 0               |
> > |   Data Type:    CELL                                                       |
> > |   Rows:         141970                                                     |
> > |   Columns:      141970                                                     |
> > |   Total Cells:  -1319355580                                                |
> >  |        Projection: Zeměpisná šířka a délka (zone 0)                        |
> > |            N: 71:26:24.830769N    S: 35:05:34.821226N   Res: 0:00:00.92167 |
> > |            E: 24:20:41.939214E    W: 12:00:08.07033W   Res: 0:00:00.921674 |
> > |   Range of data:    min =  0 max = 0                                       |
> > |   Data Source:                                                             |
> > |   Data Description:                                                        |
> >  |    generated by r.in.gdal                                                  |
> >The red channel seems to be correct, the others contain only value
> >'0'. During import process the following errors occurred:
> >ERROR 1: IReadBlock failed at X offset 0, Y offset 141969
> >ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 141969
> >I have also tried to convert ECW file to GTiff by using
> >gdal_translate, also without any success.
> >gdal_translate -of GTiff Europe\ Landsat742.ecw /mnt/hdb2/Europe\ Landsat742.tif
> >Input file size is 141970, 141970
> >0...10...20...30.ERROR 1: TryWinRasterIO() failed for blocked scanline.
> >ERROR 1: IReadBlock failed at X offset 0, Y offset 0
> >ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
> >Any idea?, best regards
> > Martin
> >PS: The value of total cells is wrong (should not be long long int
> >instead of long int)? See the attached patch.
