[GRASSLIST:10328] Re: robinson (winkel) projection
Markus Neteler neteler at itc.it
Wed Feb 15 15:25:08 EST 2006
On Wed, Feb 15, 2006 at 10:29:54AM -0800, Ian MacMillan wrote:
> Degrees would be really nice as a standard unit for these kinds of
> projections, but since their absolute length varies depending on your
> location on the earth, they can't be used in grass.  My workaround to
> this has been to make a vector grid in a latlong location that is
> spaced about ten or fifteen degrees apart for the entire earth.  I then
> project (with v.proj) that vector file into my robinson location as a
> first step so that I can see where I am in the world.
Ian,
you may want to enjoy the new d.grid which supports LatLong
grids in non-LatLong locations:
 http://grass.itc.it/grass61/manuals/html61_user/d.grid.html
 -g
    Draw geographic grid
Markus
