[GRASSLIST:10348] Re: [GRASS5] Re: i.vpoints can't read temp files
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Thu Feb 16 16:52:41 EST 2006
Thanks for the fix, Markus. i.vpoists is working, the problem now is that my
new compilation can't run d.m:
GRASS 6.1.cvs (am_sul_SAD69):~ > Error in startup script: can't read
"env(HOSTTYPE)": no such variable
    while executing
"set HOSTTYPE $env(HOSTTYPE)"
    (file "/usr/local/grass-6.1.cvs/etc/dm/d.m.tcl" line 42)
Now I only have the terminal.
Carlos
On 2/16/06, Markus Neteler <neteler at itc.it> wrote:
> On Thu, Feb 16, 2006 at 07:02:16PM +0100, Maciek Sieczka wrote:
> > On Thu, 16 Feb 2006 14:29:01 -0200
> > Carlos "Guâno" Grohmann <carlos.grohmann at gmail.com> wrote:
> > > Hello all, I just compile the last wekk CVS, and tried to rectify a
> > > raster scanned map with i.vpoints, but when I try to select a vector
> > > to be used as reference, it crashes and gives this msg at the bottom
> > > of the window: "ERROR: ask_gis_files: can't read tempfile"
> > > Any ideas?
> > Carlos
> > For the record: I confirm the behaviour you describe - I had it on my
> > friend's box with Grass 6.1 CVS from mid December 2005.
> I have debugged and found the problem - a wrong positioned
> G_free() in i.find which is called by i.points and i.vpoints.
> It's fixed in 6.1-CVS now.
> Markus
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows 95 from
my hard drive."
--The winning entry in a "What were HAL's first words" contest judged by
2001: A SPACE ODYSSEY creator Arthur C. Clarke
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060216/a4aa5ee2/attachment.html
