[GRASSLIST:10351] Re: [GRASS5] Re: i.vpoints can't read temp files
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Thu Feb 16 17:13:17 EST 2006
OK, Markus, but there's another problem now...
i.vpoints starts ok, I select my raster and my vector. If I start by zooming
in the vector, it goes well. So I zoom in the raster, select the point in
raster, then in vector. so far, so good. Now, when I try to zoom some other
area of the vector, it crashes and gives this msg: "WARNING: unable to open
raster map [name of my VECTOR here]. and then it stops....
Carlos
On 2/16/06, Markus Neteler <neteler at itc.it> wrote:
> Carlos,
> fixed (taken from gis.m) by changing:
> -set HOSTTYPE $env(HOSTTYPE)
> +if {[info exists env(HOSTTYPE)]} {
> +        set HOSTTYPE $env(HOSTTYPE)
> +} else {
> +        set HOSTTYPE ""
> Please update from CVS.
> Markus
> On Thu, Feb 16, 2006 at 07:52:41PM -0200, Carlos "Guâno" Grohmann wrote:
> > Thanks for the fix, Markus. i.vpoists is working, the problem now is
> that my
> > new compilation can't run d.m:
> > GRASS 6.1.cvs (am_sul_SAD69):~ > Error in startup script: can't read
> > "env(HOSTTYPE)": no such variable
> >     while executing
> > "set HOSTTYPE $env(HOSTTYPE)"
> >     (file "/usr/local/grass-6.1.cvs/etc/dm/d.m.tcl" line 42)
> > Now I only have the terminal.
> > Carlos
> > > On Thu, Feb 16, 2006 at 07:02:16PM +0100, Maciek Sieczka wrote:
> > > > On Thu, 16 Feb 2006 14:29:01 -0200
> > > > Carlos "Guâno" Grohmann <carlos.grohmann at gmail.com> wrote:
> > > > > Hello all, I just compile the last wekk CVS, and tried to rectify
> a
> > > > > raster scanned map with i.vpoints, but when I try to select a
> vector
> > > > > to be used as reference, it crashes and gives this msg at the
> bottom
> > > > > of the window: "ERROR: ask_gis_files: can't read tempfile"
> > > > > Any ideas?
> > > > Carlos
> > > > For the record: I confirm the behaviour you describe - I had it on
> my
> > > > friend's box with Grass 6.1 CVS from mid December 2005.
> > > I have debugged and found the problem - a wrong positioned
> > > G_free() in i.find which is called by i.points and i.vpoints.
> > > It's fixed in 6.1-CVS now.
> > > Markus
> >               Carlos Henrique Grohmann - Guano
> >   Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> > Linux User #89721  - carlos dot grohmann at gmail dot com
> > _________________
> > "Good morning, doctors. I have taken the liberty of removing Windows 95
> from
> > my hard drive."
> > --The winning entry in a "What were HAL's first words" contest judged by
> > 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> Markus Neteler     <neteler itc it>       http://mpa.itc.it
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
_________________
"Good morning, doctors. I have taken the liberty of removing Windows 95 from
my hard drive."
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060216/1d0e7fd0/attachment.html
