[GRASSLIST:10355] Re: Error in startup script: couldn't execute "ps.map": no such file or directory - grass6.0.0 on Mandriva 2006
Nagesh Bhatkar bnagesh at nio.org
Thu Feb 16 23:11:30 EST 2006
Hello Sir,
Thanks for your reply.
As u suggested, eventually i will have to switch to grass-6.0.1 and
other higher versions that will be released.
But i wanted to know if anyone else faced the same problem as mine and
if grass-6.0.0
works on mandriva 2006 without the error:
??Error in startup script: couldn't execute "ps.map": no such file or
directory?
Also i had a few addon modules written which
i was using with grass-6.0.0
Regards
Nagesh
Maciek Sieczka wrote:
>Nagesh,
>>Later i installed grass-6.0.1 and there was  no problem in its
>>installation on Mandriva 2006.
>So why don't you use 6.01 then? It is exactly the same as 6.0, only it
>contains bugfixes that are missing in 6.0. Simply put it is better
>and safer. Soon 6.02 should be comming.
>Maciek
>W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
>http://katalog.panoramainternetu.pl/
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060217/b34f9449/attachment.html
