[GRASSLIST:10422] Re: importing projection info with v.in.ogr
Maciek Sieczka werchowyna at epf.pl
Mon Feb 20 02:33:35 EST 2006
On Sun, 19 Feb 2006 18:27:03 -0500
"Chris Fonnesbeck" <fonnesbeck at gmail.com> wrote:
> On 2/19/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> > > Right. This is what is missing, however. v.in.ogr does not create
> > > PROJ_INFO in the newly-created location.
> > v.in.ogr will not modify PROJ_INFO for current location. However, if
> > used with option "location" it will create a *new* location with
> > appropriate PROJ_INFO (if the input shapefile has valid prj file),
> > and import the data subsequently into it.
> This is what I did: I imported the layer using the location option:
> v.in.ogr dsn=./ layer=cntbnd location=florida output=counties
Rigt, sorry. I must have been blind.
In that case, it is wrong that the PROJ_INFO was not created.
Send the prj file, exact v.in.ogr command output and the Grass version
you are uisng.
Even better if you could try to reproduce your problem with a current
Grass 6.1 CVS first.
Cheers
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
