[GRASSLIST:10441] connect with selection???
Massimiliano Cannata massimiliano.cannata at supsi.ch
Mon Feb 20 12:45:12 EST 2006
Hello,
currently I keep in a pg table X,Y,value,type,date of meteostation and
import the rain vector with:
echo "SELECT x,y,value FROM observation where type=rain and date='200602101200'" | db.select -c | v.in.ascii out=rain.200602101200
Conceptually the geometry is static and just the attribute are time
dependent.
So I wonder if is there a way for select vector attributes based on
WHERE statement?
What I need should be a sort of v.db.connect with table="SELECT bla bla
FROM bla bla WHERE bla bla"...
Do you have some hints for doing the rigth thing?
Thanks,
Massimiliano
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 18
Fax +41 (0)58 666 62 09
