[GRASSLIST:10454] Re: gis.m run failure
Tom Russo russo at bogodyn.org
Mon Feb 20 20:39:56 EST 2006
On Mon, Feb 20, 2006 at 06:25:45PM -0700, we recorded a bogon-computron collision of the <russo at bogodyn.org> flavor, containing:
> I have been a command-line bigot forever, and rarely use the d.m or gis.m
> features of GRASS --- I once tried gis.m and liked what I saw, but don't
> use it routinely, and indeed haven't tried it in a few weeks.  As for
> d.m, my first command on starting GRASS is typically "File->Exit" in d.m.
> After all this talk of revamping GRASS so that the X displays can go away, I
> decided to try out gis.m again lest I fall so far behind the times that
> GRASS becomes unusable for me overnight.  Using grass-6.1 cvs updated last
> night, I get:
> > gis.m
> Error in startup script: bad event type or keysym "ConfigureRequest"
>     while executing
> "bind .mapcan($mon) <ConfigureRequest> {
> Any hints on where to look for what's wrong here?  Could this be a tcl/tk
> versioning issue?  (I'm using tcl/tk 8.3, although I do have tcl 8.4 installed
> --- just not set up so that configure finds it, coz once upon a time 8.4 was
> unusable with grass.)
Google to the rescue.  Yes, ConfigureRequest is something that is only present
in tcl 8.4.
If this incompatibility with tcl/tk 8.3 is necessary for proper function of
gis.m, the various install documents should ultimately be updated, and
perhaps configure should not accept tcl/tk 8.3 anymore.
Re-adjusting my tcl/tk 8.3 vs. 8.4 install and letting grass use 8.4 fixed
gis.m.
Tom Russo    KM5VY     SAR502  DM64ux         http://www.swcp.com/~russo/
Tijeras, NM  QRPL#1592 K2#398  SOC#236 AHTB#1
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
 one trick, rational thinking, but when you're good and crazy, oooh, oooh,
 oooh, the sky is the limit."  --- The Tick
