[GRASSLIST:10466] Re: QGIS/GRASS for Windows 060217
Radim Blazek radim.blazek at gmail.com
Tue Feb 21 05:17:21 EST 2006
On 2/21/06, Manuel Seeger <seeger at uni-trier.de> wrote:
> I have the same problem with qgis and grass from rpm installation on SuSe
> 10.0!
> Spearfishh or my own rasters dont get loaded, same error warning.
That can be hardly for the same reason as on Windows.
Most probably your gdal is not compiled with GRASS, try
gdalinfo --formats
Radim
> Greetings from snowy germany
> manuel
> Am Dienstag, 21. Februar 2006 10:52 schrieben Sie:
> > On 2/20/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> > > > However, when trying to open any grass raster, I get the following
> > > > error:
> > > > "C:/..../locations//spearfish60/PERMANENT/cellhd/elevation.10m is not a
> > > > supported raster data source".
> > > > Is raster processing still unstable or are maybe specific read/write
> > > > privileges to be set ?
> > Today I tested GRASS rasters with qgis-0.7.9-win32-060217
> > and Spearfish and it works for me.
> > Do you have other versions of GDAL on your system?
> > It should not be problem because Windows should first search for
> > DLL in the directory where application is located.
> > Anybody other had success/problems with GRASS rasters?
> > Radim
> Dr. Manuel Seeger
> Wiss. Assistent                                         Scientific Assistant
> Physische Geographie                                    Dpt. of Physical Geography
> FB VI - Geographie/Geowissenschaften            Geography/Geosciences
> Universität Trier                                               University of Trier
> D - 54286 Trier
> Tel.:           +49-651-201 4557
> Fax:            +49-651-201 3976
> Web:    http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
