[GRASSLIST:10469] Re: QGIS/GRASS for Windows 060217
Manuel Seeger seeger at uni-trier.de
Tue Feb 21 06:27:09 EST 2006
Thank you!
You seem to be right, so, there is no GRASS format listed. how can I introduce
GRASS formats?
I used the rpms from gdf... before I hat compiled my own version, but did not
get qgis compiled, so I tried with packages from gdf. Vector format works
fine.
Thanks in advance
Manuel
Am Dienstag, 21. Februar 2006 11:17 schrieben Sie:
> On 2/21/06, Manuel Seeger <seeger at uni-trier.de> wrote:
> > I have the same problem with qgis and grass from rpm installation on SuSe
> > 10.0!
> > Spearfishh or my own rasters dont get loaded, same error warning.
> That can be hardly for the same reason as on Windows.
> Most probably your gdal is not compiled with GRASS, try
> gdalinfo --formats
> Radim
> > Greetings from snowy germany
> > manuel
> > Am Dienstag, 21. Februar 2006 10:52 schrieben Sie:
> > > On 2/20/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> > > > > However, when trying to open any grass raster, I get the following
> > > > > error:
> > > > > "C:/..../locations//spearfish60/PERMANENT/cellhd/elevation.10m is
> > > > > not a supported raster data source".
> > > > > Is raster processing still unstable or are maybe specific
> > > > > read/write privileges to be set ?
> > > Today I tested GRASS rasters with qgis-0.7.9-win32-060217
> > > and Spearfish and it works for me.
> > > Do you have other versions of GDAL on your system?
> > > It should not be problem because Windows should first search for
> > > DLL in the directory where application is located.
> > > Anybody other had success/problems with GRASS rasters?
> > > Radim
> > Dr. Manuel Seeger
> > Wiss. Assistent                                         Scientific
> > Assistant Physische Geographie                                    Dpt. of
> > Physical Geography FB VI - Geographie/Geowissenschaften
> > Geography/Geosciences Universität Trier
> >             University of Trier D - 54286 Trier
> > Tel.:           +49-651-201 4557
> > Fax:            +49-651-201 3976
> > Web:    http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
Dr. Manuel Seeger
Wiss. Assistent						Scientific Assistant
Physische Geographie					Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften		Geography/Geosciences
Universität Trier						University of Trier
D - 54286 Trier
