[GRASSLIST:10480] Re: importing projection info with v.in.ogr
Markus Neteler neteler at itc.it
Tue Feb 21 10:29:57 EST 2006
On Tue, Feb 21, 2006 at 10:05:35AM -0500, Chris Fonnesbeck wrote:
> On 2/20/06, Markus Neteler <neteler at itc.it> wrote:
> > Chris,
> > what does g.proj -p say?
> Hi Markus,
> It says:
> XY location (unprojected)
Hi Chris,
that's the problem. AFAIK you cannot generate projection info
in a XY location (doesn't make sense).
But try to add the "location=" parameter to create a *new* location
from the data set. This you can do in the XY location without
problems.
Markus
