[GRASSLIST:10496] Re: importing projection info with v.in.ogr
Maciek Sieczka werchowyna at epf.pl
Tue Feb 21 15:15:25 EST 2006
On Mon, 20 Feb 2006 18:09:33 -0500
"Chris Fonnesbeck" <fonnesbeck at gmail.com> wrote:
> On 2/20/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> > My output is as follows. How does your compare?
> Here is my output from the same command. It does not result in a
> PROJ_INFO file in the location:
No good. Your version of Grass 6.1 has the bug in the code responsible
for handling PROJ_INFO file for sure. It has been fixed recently. If
you can't get a newer Grass, you'll need to reproject your shapefile
outside the Grass, using ogr2ogr which I mentioned before.
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
