[GRASSLIST:10520]
Kirk R. Wythers kwythers at umn.edu
Wed Feb 22 09:32:02 EST 2006
Is there a way to specify the layer (table) that comes up to
interactively edit attributes in d.what.vect? In my case I have 2
layers (ie tables) associated with a particular vector map. If I
display the vector map with d.vect 'map_name' then run d.what.vect -e,
the form that comes up only has the first layer (table) in it. I
would like to edit layer 2, by clicking on the polygon in the vector
map.
Is that possible?
Thanks,
Kirk
