[GRASSLIST:10524] Re: d.what.vect issue with multiple layers
Maciek Sieczka werchowyna at epf.pl
Wed Feb 22 14:54:29 EST 2006
On Wed, 22 Feb 2006 08:33:24 -0600
"Kirk R. Wythers" <kwythers at umn.edu> wrote:
> Is there a way to specify the layer (table) that comes up to
> interactively edit attributes in d.what.vect? In my case I have 2
> layers (ie tables) associated with a particular vector map. If I
> display the vector map with d.vect 'map_name' then run d.what.vect -e,
> the form that comes up only has the first layer (table) in it. I
> would like to edit layer 2, by clicking on the polygon in the vector
> map.
> Is this possible with d.what.vect?
For me, d.vect -e on a 2 layer vector file works. In the upper part of
the window there is "Layer 1", in the lowe part there is "Layer 2".
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
