[GRASSLIST:10532] Re: Dxf and other 3d objects in NVIZ
Nick Cahill ndcahill at facstaff.wisc.edu
Thu Feb 23 02:52:57 EST 2006
I also tried for some time to get 3d shapes from a CAD file into
GRASS as 3d vectors. I used lots of different methods - extruded
shapes (like v.extrude but in CAD), individual faces/surfaces, etc.,
and never had anything come out right in GRASS. I was using v.in.ogr
to import Microstation .dgn files - which works fine for 2d vectors,
and for 2 1/2d vectors -- contour lines with elevation -- but not for
proper 3d objects.
Nick Cahill
On Feb 23, 2006, at 8:19 AM, Michael Barton wrote:
> You can use v.extrude for buildings. I tried it and it is pretty
> slick.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> From: Paul Shapley <p.shapley at gmail.com>
> Date: Wed, 22 Feb 2006 11:04:53 +0000
> To: <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:10514] Dxf and other 3d objects in NVIZ
> Hi All,
> I'm new to the list but not Grass which i use primarily on Mac OS
> X. Is there an alternative option to getting 3d objects into NVIZ.
> I have tried to obtain the v.in.dxf (OpenDWG Toolkit) but have failed.
> Has anyone had success with buildings or Windturbines in thier
> correct geographic positions. I have a '.dxf' instances i would
> like to import.
> Thanks,
> Paul Shapley
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060223/4ca71bc4/attachment.html
