[GRASSLIST:10538] Re: importing PROJ_INFO
Ian MacMillan Ian.MacMillan at pomona.edu
Thu Feb 23 18:19:10 EST 2006
Chris, my guess is that in the default_wind or wind files, you will
also have to change the projection numerical code.  I think it is the
first line.
G'luck
-Ian
On Feb 23, 2006, at 3:07 PM, Chris Fonnesbeck wrote:
> Is there any way of convincing a location to use the projection
> information in the PROJ_INFO file? I have added the correct projection
> information to a PROJ_INFO file in the PERMANENT directory, but still
> when I call g.proj -p it does not detect the new informaiton, and
> simply prints "Unprojected (X,Y)". Is there a formal way of importing
> this?
> Thanks,
> C.
> Chris Fonnesbeck + Atlanta, GA + http://trichech.us
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by Postini anti-virus software.
