[GRASSLIST:10560] Re: TOPIDX flow direction algorithm
twiens twiens at interbaun.com
Fri Feb 24 14:05:13 EST 2006
Thanks. I'll check it out.
T
----- Original Message Follows -----
From: Dylan Beaudette <dylan.beaudette at gmail.com>
To: twiens at interbaun.com
Cc: GRASSLIST at baylor.edu, grass4u at gmail.com
Subject: [GRASSLIST:10558] Re: TOPIDX flow direction
algorithm
Date: Fri, 24 Feb 2006 10:44:30 -0800
> I would highly recommend enabling c++ support when you
> compile GRASS, so that  you have access to the r.terraflow
>  This will compute a TCI, and in many  cases I have found
> the output from r.terraflow to be superior to the
> analogous commands in GRASS.
> cheers,
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
