[GRASSLIST:10564] Re: r3.out.v5d
Maciek Sieczka werchowyna at epf.pl
Sat Feb 25 03:19:34 EST 2006
On Fri, 24 Feb 2006 16:48:15 -0300 (BRST)
andrea.iescheck at ufpr.br wrote:
> Hi,
> I exported my grid3d data to vis5d but an error is reported when I
> try to import the generated v5d file in vis5d.
> It seems that the command r3.out.v5d is interrupted before the end,
> but the v5d file is created!
Post exact command syntax and output, including error. I'm not saying I
will be able to help you but in order for anyone to be able to you must
be specific.
> I´ve installed grass 6.0.0 GNU.
Cheers,
Maciek
W polskim Internecie są setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
