[GRASSLIST:10589] Re: GRASS 6.1cvs gis.m error
Ing.Peter Misovic peter.misovic at gmail.com
Sun Feb 26 14:02:42 EST 2006
Yes, I understand the concept. It works fine now. I've started Grass
from folder with limited write permissions.
I have question in regard of this issue. Is it problem to find out in
script (code) from system WHO is starting script ? If it is not, the
script could create temp (etc.) files directly into home directory of
user who has started this script. Even if the sctipt is not starting
from user's home directory.
Peter
On 2/26/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Ing.Peter Misovic wrote:
> > I'd like to ask you for help with gis.m Grass manager. Manager is not
> > starting properly 'cause it is crashing with following error :
> > ERROR: PNG: couldn't open output file dispmon_1.ppm
> The PNG driver is trying to save its files in the current directory.
> If you don't have write permission on that directory, it will fail.
> Similarly, if the file already exists but you don't have write
> permission on it, it will fail.
> ISTR that later versions of gis.m tell the PNG driver to put the files
> in a temporary directory.
> Either cd to a directory for which you have write permission, or
> update to a more recent version of gis.m. In any event, you should do
> the latter sooner rather than later, as gis.m is under active
> development.
