[GRASSLIST:10600] Re: GRASS 6.1cvs gis.m error - raster/r.le/r.le.setup
Ing.Peter Misovic peter.misovic at gmail.com
Sun Feb 26 17:34:32 EST 2006
Markus, this is error you've asked (occures after make command) in
raster/r.le/ folder.
[misovic at thailon r.le.setup]$ make
Makefile:16: warning: overriding commands for target `clean'
../../../include/Make/Rules.make:34: warning: ignoring old commands
for target `clean'
gcc -I/home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_25/dist.i686-pc-linux-gnu/include
 -O3 -mcpu=pentium4 -Wall  -Wall -Wconversion -Wno-implicit-int
-I/usr/local/include     -DPACKAGE=\""grassmods"\"
        -o OBJ.i686-pc-linux-gnu/sample.o -c sample.c
`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
sample.c: In function `sample':
sample.c:39: warning: unused variable `btn'
sample.c: In function `man_unit':
sample.c:554: warning: passing arg 1 of `G_calloc' as unsigned due to prototype
sample.c:555: warning: passing arg 1 of `G_calloc' as unsigned due to prototype
sample.c:113: warning: unused variable `dx'
sample.c:113: warning: unused variable `dy'
sample.c:114: warning: unused variable `l0'
sample.c:114: warning: unused variable `t0'
sample.c:114: warning: unused variable `randflag'
sample.c:115: warning: unused variable `itmp'
sample.c:117: warning: unused variable `al'
sample.c:117: warning: unused variable `ar'
sample.c:117: warning: unused variable `at'
sample.c:117: warning: unused variable `ab'
sample.c:117: warning: unused variable `au_w'
sample.c:117: warning: unused variable `au_l'
sample.c:120: warning: unused variable `sites_mapset'
sample.c:121: warning: unused variable `wind'
sample.c: In function `draw_grid':
sample.c:653: warning: unused variable `k'
sample.c:653: warning: unused variable `itmp'
sample.c:653: warning: unused variable `tmp'
sample.c: In function `calc_unit_loc':
sample.c:821: warning: suggest parentheses around assignment used as truth value
sample.c:727: warning: unused variable `region'
sample.c:729: warning: unused variable `k'
sample.c:730: warning: unused variable `tmp'
sample.c: In function `graph_unit':
sample.c:1052: warning: unused variable `tmpw'
sample.c:1052: warning: unused variable `tmpl'
sample.c: In function `draw_circle':
sample.c:1487: warning: unused variable `x2'
sample.c:1487: warning: unused variable `yr'
sample.c: In function `numtrap':
sample.c:1537: warning: unused variable `j'
sample.c: In function `calc_num':
sample.c:1013: warning: 'max' might be used uninitialized in this function
sample.c:994: internal compiler error: in convert_move, at expr.c:566
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:https://qa.mandrakesoft.com/> for instructions.
make: *** [OBJ.i686-pc-linux-gnu/sample.o] Error 1
Peter
On 2/26/06, Ing.Peter Misovic <peter.misovic at gmail.com> wrote:
> On 2/26/06, Markus Neteler <neteler at itc.it> wrote:
> > On Sun, Feb 26, 2006 at 09:37:26PM +0100, Ing.Peter Misovic wrote:
> > > Things are going to be complicated. As I wrote, I started gis.m from
> > > directory with right permissions and it works fine. I liked to try
> > > last gis.m from your site Michael. So I copied sources of v.what into
> > > vector folder of Grass and started to configure and make Grass again
> > > (if I understand it, I have to do that way) - to make newer version od
> > > v.what. But :
> > > Generating HTML manual pages index (help system)...
> > > Generated HTML docs in ../dist.i686-pc-linux-gnu/docs/html/index.html
> > > Following modules are missing the 'description.html' file in src code:
> > > g.pnmcomp
> > g.pnmcomp is still lacking a description.html file. If not intented
> > to the end user, it should probably go into ETC?
> > > GRASS GIS compilation log
> > > Started compilation: Sun Feb 26 21:10:15 CET 2006
> > > Errors in:
> /home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_20/raster/r.le/r.le.setup
> > Can you please go into the r.le.setup directory and run make?
> I'm sorry for that but I've deleted untared directory and I'm
> installing again. Id the same error occures, I shall write an email.
> /home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_20/vector/v.what
> > > Finished compilation: Sun Feb 26 21:27:04 CET 2006
> > > (In case of errors please change into the directory with error and run
> > 'make')
> > > I tried to make it directly in v.what folder but :
> > > [misovic at thailon v.what]$ make
> > > gcc
> -I/home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_20/dist.i686-pc-linux-gnu/include
> > >         -o OBJ.i686-pc-linux-gnu/main.o -c main.c
> > > main.c:24:21: glocale.h: No such file or directory
> > > main.c:25:17: gis.h: No such file or directory
> > > main.c:27:18: Vect.h: No such file or directory
> > > main.c:28:20: raster.h: No such file or directory
> > > main.c:30:18: dbmi.h: No such file or directory
> > > main.c:32:20: config.h: No such file or directory
> > > main.c: In function `main':
> > > main.c:40: error: storage size of 'window' isn't known
> > did you run 'configure' as well?
> > The position of the include files was modified recently.
> No, I've just run make ... configuration was done before for whole Grass.
> Peter
> > Markus
> > > Please, would I stay with old v.what from
> > > grass-6.1.cvs_src_snapshot_2006_02_20 in combination with news gis.m
> > > and gm folder or is better to make it with untouched original source
> > > of CVS Grass.
> > > Thank you,
> > > if it is just because of development I understand and I shall wait.
> > > Peter
> > > > Yes, I understand the concept. It works fine now. I've started Grass
> > > > from folder with limited write permissions.
> > > > I have question in regard of this issue. Is it problem to find out in
> > > > script (code) from system WHO is starting script ? If it is not, the
> > > > script could create temp (etc.) files directly into home directory of
> > > > user who has started this script. Even if the sctipt is not starting
> > > > from user's home directory.
> > > > Peter
> > > > > > I'd like to ask you for help with gis.m Grass manager. Manager is
> > not
> > > > > > starting properly 'cause it is crashing with following error :
> > > > > > ERROR: PNG: couldn't open output file dispmon_1.ppm
> > > > > The PNG driver is trying to save its files in the current
> directory.
> > > > > If you don't have write permission on that directory, it will fail.
> > > > > Similarly, if the file already exists but you don't have write
> > > > > permission on it, it will fail.
> > > > > ISTR that later versions of gis.m tell the PNG driver to put the
> files
> > > > > in a temporary directory.
> > > > > Either cd to a directory for which you have write permission, or
> > > > > update to a more recent version of gis.m. In any event, you should
> do
> > > > > the latter sooner rather than later, as gis.m is under active
> > > > > development.
> > Markus Neteler     <neteler itc it>       http://mpa.itc.it
> > ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> > MPBA - Predictive Models for Biol. & Environ. Data Analysis
> > Via Sommarive, 18        -       38050 Povo (Trento), Italy
