[GRASSLIST:10612] Re: GRASS 6.1cvs gis.m error - raster/r.le/r.le.setup
Ing.Peter Misovic peter.misovic at gmail.com
Mon Feb 27 14:17:09 EST 2006
Thank you, I thought so ....
Peter
On 2/27/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Ing.Peter Misovic wrote:
> > Markus, this is error you've asked (occures after make command) in
> > raster/r.le/ folder.
> > [misovic at thailon r.le.setup]$ make
> > Makefile:16: warning: overriding commands for target `clean'
> > ../../../include/Make/Rules.make:34: warning: ignoring old commands
> > for target `clean'
> > gcc -I/home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_25/dist.i686-pc-linux-gnu/include
> >  -O3 -mcpu=pentium4 -Wall  -Wall -Wconversion -Wno-implicit-int
> > -I/usr/local/include     -DPACKAGE=\""grassmods"\"
> >         -o OBJ.i686-pc-linux-gnu/sample.o -c sample.c
> > `-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
> [snip]
> > sample.c:994: internal compiler error: in convert_move, at expr.c:566
> > Please submit a full bug report,
> > with preprocessed source if appropriate.
> > See <URL:https://qa.mandrakesoft.com/> for instructions.
> It's an internal compiler error (i.e. an error in the compiler, not
> the file it's trying to compile). As it says, report it to whoever
> built gcc (i.e. Mandrake). I doubt that there is anything that we can
> do about it.
